Intercooler Comparo....Custom Garrett vs. VSRacing (E-Bay)
Old Jan 25, 2014 | 08:49 PM
OldGold's Avatar
This test holds up on the street as well. A drop in IAT as soon as the power is applied with it either slowly leveling off, or a very small rise. This intercooler is doing work.
Mike
Old Jan 25, 2014 | 09:31 PM
LSM3's Avatar
How is it a comparison if one core is 65% thicker? I'm sure the quality core will be more efficient but I don't really think this comparison proves it...
Old Jan 26, 2014 | 12:15 PM
OldGold's Avatar
It is a comparison of two intercoolers that were on my car. It is not intended to be anything other than that.
Mike
Old Jan 26, 2014 | 12:33 PM
trans2000am's Avatar
Kind of hard to compare when all the cheap intercoolers are no more then 3" thick, I wouldn't use those eBay intercoolers over 700hp
Old Jan 26, 2014 | 12:34 PM
2000RATA's Avatar
Temperatures are rising quite a bit with the cheap core, and that's injecting methanol too.
So I'd hardly see it as doing a great job ?
I agree. Absolutely an inadequate intercooler at this power level. Probably ok to 500 WHP or so. I mean 700 HP rated is not 700 WHP through an auto!
Thanks for sharing this good info!
Old Jan 26, 2014 | 02:02 PM
OldGold's Avatar
The whole point of this exercise was to show you what can be gained when you go from the generic 3-4 inch core E-Bay coolers that are found on many builds, to a quality (and yes larger) core that many are skeptical of spending money on. I too was skeptical and wondering if this costly upgrade would be worth anything. But, I did it and wanted to share the data.
Mike
Old Jan 27, 2014 | 04:29 PM
stevieturbo's Avatar
Although for the most part, when the cheap units only cost around $100....it is kind of hard to overlook them, and they do perform ok in a lot of cases.
But as you say, for a few hundred dollars you can get a much superior unit that will yield better results everywhere.
One area that I think always fails with the cheap units is end tank design. Although the cores are poor, I reckon they would perform far better with a much more open end tank design.
Old Feb 19, 2014 | 03:15 PM
OldGold's Avatar
Some more data for this thread. Here is an actual low 9 second pass down the 1/4 for review. You will note that the ambient was over 100 degrees at the beginning, and the average over the pass was 87.6. You can clearly see the IATs take a nice dip as the car starts moving (and meth is spraying) with a slow increase over the pass. IATs never went as high as ambient.
