Turbosmart vs precision wastegates
I don't even know what size I need.
More home work to do.
As said before all of the gates mentioned in this thread are good, it just comes down to personal preference.
Basically, with wastegates, it all depends on what your using for a boost controller. Compressed air(AMS1000/2000)? or a standard electronic valve design(eboost or a simple manual).
Using compressed air? JGS(no diaphragm). WORKS AWESOME, and is lower priced then TiAL.
Not using compressed air? TiAL(uses diaphragm $50 bucks to replace) or whoever else your comfortable with.
I had turbosmart 38s, didn't do what I needed...I run MVR 44's now and work fine but, eventually, I will probably switch to JGS when I go to the AMS2000.
If you run LOW C02 pressure on the TiAL you may not tare or rip the diaphragm but we do sell a lot of them as replacements.
