Best lq9 cylinder head
Old Jan 27, 2014 | 04:25 AM
Daniel Nicastri's Avatar
Default Best lq9 cylinder head
What's the best bang for buck cylinder head for a lq9 408 rectangle port intake for single 80mm turbo
Old Jan 27, 2014 | 05:37 AM
99WS6_'s Avatar
Stock some 317 it gives lower comp and heard it flows well...aftermarket it an be some afr 230cc with 72cc chambers
Old Jan 27, 2014 | 06:07 AM
HexenLord's Avatar
LS3 heads. Flow close to what aftermarket cathedral port heads do, and are $1000 new with valves/springs installed from Scoggin Dickey.
Old Jan 27, 2014 | 08:41 AM
Preston99WS6's Avatar
For boost I would roll with LSA's because there decks are thicker and made out of stronger aluminum they cost a little more but IMO its worth it to not have to worry about lifting the heads. LS3/L92's seem to be hit or miss when it comes to boost, some people get away with them and dont lift the heads others have problems. From what I gather all it takes is a little bit of detonation and you will be changing head gaskets at the minimum with LS3/L92's, on the other hand LSA's take a little more abuse which makes them more reliable in a FI application.
You cant beat the flow out of the box of the rectangle ports though as far as bang for your buck.
Old Jan 27, 2014 | 09:39 AM
chevellepowered's Avatar
l92 heads ,, can find them for 600 bucks ..
Old Jan 27, 2014 | 03:01 PM
1CAMWNDR's Avatar
Agree with above. L92s are where it's at. Throw some good vlaves and valve job on them and you have amazing potential for cheap.
Old Jan 27, 2014 | 05:04 PM
I have L92 already unported just trying to work out whether to port them or buy a new set of heads
