Planning P1SC
Old Jan 28, 2014 | 09:27 AM
Mista Blazer's Avatar
Default Planning P1SC
So I have been looking around for a FI kit but decided to just build one over time. My a/c compressor died so I decided to go ahead and pull it along with the lines and condensor. I originally wanted to go Turbo but I don't want to part with my long tubes and kooks true duals lol.
So my question Is do they make a bracket to put the p1sc down where the compressor goes? The blocks have a few bolt holes I feel like would be a great To mount a bracket there.
Old Jan 28, 2014 | 09:39 AM
CALL911's Avatar
ATI makes a bracket to mount their superchargers, but it is on the drivers side, not the passengers side where your AC compressor goes. No one that I am aware of makes aftermarket brackets. However, if you found someone who knows how to fabricate, I am sure you could probably have one made. But then you also have to take in consideration that all the charge piping will need to be custom made as well since ATI's piping is meant for it to be mounted on the other side. This along with the intake piping.
You can make just about anything if you are willing to invest the amount of time and money required.
Old Jan 28, 2014 | 09:59 AM
Damn. Well at least I can always put the A/C back in lol. My only concern is that when I was putting my LQ together I miss drilled the alternator lol I managed to drill it to M10x1.50 xD so I had to thread a helix in there to get my "special bolt" to fit and hold the alternator. But worst case is when I pull the block to rebuild it in a few years I have it properly fixed
