The Gap Thread - Spark plugs
Old Feb 7, 2014 | 05:58 AM
Blackbirdws6's Avatar
Default The Gap Thread - Spark plugs
I'm picking up my new engine on Saturday and already purchased a set of NGK BR7EF plugs. Most seem happy with their performance but what gap would you recommend I run? I'm pushing max ~19-20psi from a F1A and was thinking 0.028-0.030 would be ideal. Not that it should matter but this is a LT1 car.
Old Feb 7, 2014 | 06:15 AM
Shownomercy's Avatar
Man-Crush Warning
I think stock gap is around ~.055 good sir, the "OPTI" won't like such a tight gap and may blow the coil.
Old Feb 7, 2014 | 06:53 AM
x275radial's Avatar
I was gonna gap mine around .045 and give it a shot.
Old Feb 7, 2014 | 08:29 AM
Tally TransAm's Avatar
I gap my BR7EF's around .030-.032. never had an issue
Old Feb 7, 2014 | 11:19 AM
silver_82's Avatar
Use as much as you can get away with. Ive had to bring the gap to .016 on mine when i was at 26psi. More than that and the coils wouldnt fire and the engine would break up badly. I was at .24 at 18psi.
Whats the ingnition system consist of?
Old Feb 7, 2014 | 01:14 PM
JoeMama's GTO's Avatar
I run the stock .024 on mine, 680 to the wheels.
Old Feb 7, 2014 | 01:52 PM
I was running AC Delco R42-LTS when I was pullied for 15-19 lbs (710rwhp) of boost and didn't appear to have any issues. Gap was 0.035 but on recent inspection, they appeared to be a little hot for the combo. I am running the EFI LS1 PCM conversion for the LT1 cars so I no longer have an opti. The conversion uses 8 LS truck coils and the LS1 PCM. It's been a great setup so far.
Sounds like somewhere around 0.030 should be a good starting point.
Old Feb 7, 2014 | 11:39 PM
coolmanvette75's Avatar
I have the same plugs gapped at .025 going into mine Brian...
Old Feb 8, 2014 | 02:27 PM
trans2000am's Avatar
for that much boost i would think you would blow out the spark at high rpm with gapping them at .30
Old Feb 8, 2014 | 07:46 PM
Johnv's Avatar
Depending on how much of a pain they are to change , I would start at 25 thou and go down from there if you experience breaking up.
Old Feb 8, 2014 | 07:49 PM
danieloneil01's Avatar
quarter inch?
Old Feb 8, 2014 | 08:09 PM
robsquikz28's Avatar
my old lt1 was a br8 plug at .032 19lbs boost
