Twin Turbo Intercooler?
Old Feb 23, 2014 | 08:10 PM
Cubicylndr's Avatar
Originally Posted by wicked z28
Here is some info on the one im looking at buying. Core Size, 25″ X 6″ X 3.5″1-3″ outlet and 2-2.5″ inletsOutlet is angled 15 degrees1453 CFM flow rate968 HP efficient1.5psi pressure drop at 1453cfmIntroducing the newly design TRTTC9 Intercooler
Is their a general rule when comparing core size to hp rating at all?
Old Feb 23, 2014 | 10:46 PM
wicked z28's Avatar
Not sure what core size are you proposing?
Old Feb 24, 2014 | 03:50 AM
stevieturbo's Avatar
Quoting core sizes by HP is just plain stupid.
And the general rule...bigger is better.
Old Feb 26, 2014 | 10:29 PM
wicked z28's Avatar
Bump ttt
Old Mar 22, 2014 | 09:10 AM
samdogmx's Avatar
So far only done street tuning so no 1/4 mile data, but over 6.5 seconds at 17-18 psi I've seen pre IC temp of 235 and post IC temps of 112, water/meth is off. Also seeing roughly 1.2 to 1.5 psi pressure drop across the IC This is with the 9" dual in/single out Treadstone.
Old Mar 23, 2014 | 05:45 PM
oscs's Avatar
What was the ambient temperature?
Old Mar 23, 2014 | 07:15 PM
samdogmx's Avatar
idk was probably around low 60s high 50s
