And For Today’s Installment of NAME THAT SOUND…
The valve now operates as it should. BUT I am getting this odd popping noise when the valve is fully open. Is this normal? It only occurs when the valve is open and immediately goes away as soon as I bring up the manifold pressure to close the valve.
I never had this noise when the Tial would open with the 11 psi spring but I have changed a couple things with the intake pipe along with changing the spring. I moved my IAT sensor and meth nozzles as well as got rid of my MAF. I can’t imagine any of those changes would cause such a noise.
I have verified the noise is definitely coming from the intake pipe. I am not referring to the popping sound coming from the exhaust.
So, any idea what this sound is?
Jayson
A supercharger set up should run like a 5psi spring. The lightest spring pressured offered for your particular BOV.
Your BOV should be fully open at idle on a blower car. As soon as you tip the throttle, the valve should start closing, be fully closed at zero lbs of vacuum. Then open immediately with ANY vacuum. Have you confirmed this is the way it operates on your car?
If you have to stiff of a spring, the boost will actually push the valve open instead of the vacuum pulling it open. Then try to close prematurely. Defeating the purpose of the BOV.
There are two lighter springs available; 7 and 3 psi spring pressure. I am concerned that the green (3 psi spring pressure) spring is too light. I would prefer the car not sound like a street sweeper all the time. Since this BOV was installed by a previous owner for primarily sound and is a secondary BOV I was hoping to tame it a bit and not have it open all the time.
The BOV is operating just as I would like/expect it to with the new white spring. It now opens at idle, deceleration, and during shifts, unlike my previous spring. The only concern is the popping (flutter) sound.
I was going back and forth over getting the white or black spring (-9 psi spring pressure vs -7). Seems like I may have picked the wrong one…
It's a supercharger, their loud. The only way to kind of get away from the blowing air sound at cruise is to recirculate the air back to the inlet hat. You will loose your BOV sound though. Can't have one with out the other, and it not have an ill effect on your blower. A blower not being able to vent properly is worse than a turbo not venting properly.
I like the air sound coming from the BOV but I don't like the sound of marbles in my intake. On another forum a member said he had the same thing and what solved it for him was moving the BOV further away from the throttle body (about 8 inches). Not sure what that means. Pressure wave from throttle body? No idea...
