Efisource 3 bar map (denmah) users
Old Feb 25, 2014 | 02:21 PM
Burken01's Avatar
Originally Posted by Ryans99ls1
Yes.
See this makes me nervous that its same problem i had. Back when i first got the car, someone flashed a stock 01 OS onto my 99 saying it was faster/better (i just wanted my O2's turned off). Ever since we did that, the thing was a bitch to tune and it really showed its face when i went SD. When i remembered that and mentioned it to my current tuner, he reflashed everything back to the way it came from the factory and started clean. No problems since.
Well since my car is a 98 and I'm using a 01 pcm I would have to flash back to a stock 01 tune correct? Then just start over?
How many "write entire" can you do before the PCM is trash
Old Feb 25, 2014 | 02:23 PM
Burken01's Avatar
Originally Posted by edwardzracing
The alternator/generator code will not keep the car from running. I had that code as well after repinning mine. If you want to fix that, run a wire from RED connector, PIN 15 to the B pin on the alternator plug. Until I did this, my alternator wasn't even working.
Have you ran the car SINCE doing the re-pin? Like before you did all the turbo stuff?
No haven't run the car since the repin, this is the first attempt
Old Feb 25, 2014 | 02:27 PM
Ryans99ls1's Avatar
Yeah, just bring the PCM back to its factory settings and go from there (unless someone has better ideas).
I didnt know there was a limit on how many times you could "write entire" the PCM but i am a complete noob in the tuning world.
Old Feb 25, 2014 | 02:37 PM
Burken01's Avatar
Yeah they say to only write entire once, but you can do calibrations a million times..
I'll look into it
Old Feb 25, 2014 | 02:47 PM
Ryans99ls1's Avatar
I'll look into it
Ahh makes sense now. When my tuner did it, i remember him saying cross your fingers and hope this works lol. Either way, it worked.
Old Feb 25, 2014 | 03:02 PM
edwardzracing's Avatar
I'll look into it
I've done quite a few complete writes on my PCM, but I use efilive, not sure why it would be any different, but I don't see why doing another "write entire" is going to hurt anything... just make sure your car battery has a good charge.
If I were you, I'd get a stock tune back on it. I'd get a stock MAP sensor back in it and then try to fire it up without touching anything other than maybe the injectors... do you have proper data for the injectors? I think Denmah said he has the info in some of his tunes, you could certainly download one of those from his site.
Keep us posted.
Old Feb 25, 2014 | 03:36 PM
Burken01's Avatar
Keep us posted.
I'll double check on the injector data, my break in tune was done by lsxpowertuning so I'm pretty dang sure he has the right data In it.
Old Feb 26, 2014 | 12:29 AM
RonSSNova's Avatar
Which map did you buy? The GM brick style or the direct fit one I just saw on their website?
I guess I'm wondering where they sourced that one.....esp for the price.
Old Feb 26, 2014 | 02:23 AM
Burken01's Avatar
Gm brick style
I did a boost leak test again and have a leak around the injectors, but don't think that's my problem.
However ill fix it before I attempt another start!
Old Feb 26, 2014 | 10:38 PM
Burken01's Avatar
Ok got it started tonight! Woo finally!
It was driving me nuts for a minute!
Old Feb 27, 2014 | 02:59 AM
RonSSNova's Avatar
Congratulations!
Old Feb 27, 2014 | 03:13 AM
  #32
Burken01's Avatar
Congratulations!
Thanks, finally got that turbo monkey off my back
Old Feb 27, 2014 | 04:35 AM
  #33
SSZ's Avatar
SSZ
Do you know what ended up being the issue?
Old Feb 27, 2014 | 05:32 AM
  #34
95bowtie's Avatar
What was the the issue then? What did you do to solve it?
Old Feb 27, 2014 | 01:03 PM
  #35
Burken01's Avatar
No he just adjusted the break in tune (fuel, ve,) and a couple other things and it started right up.
It's idling rich so he just emailed another tune so hopefully everything goes smoothly..
Old Feb 27, 2014 | 02:16 PM
  #36
Would be very interesting to compare the original tune versus the one that worked. Congrats on getting it going!
Old Feb 27, 2014 | 07:14 PM
  #37
SSZ's Avatar
SSZ
Yes. I second this comment.
Old Nov 13, 2014 | 12:38 PM
  #38
ryanleiker's Avatar
For the efisource brick style 3 bar, how should I have wired it in?
I put the red wire to power, black wire to ground, and yellow wire to signal, all from the original intake map pigtail.
When in my scanner, I'm reading almost a constant 90 kpa and it hardly moves at all. It's idling rich and I'm unsure where the scaling and offsets for my map are in hptuners that I keep reading about...
Could my wiring be wrong?
I've only been playing with this software for about 3 weeks now.
According to these two diagrams and pictures, I have my power and signal wires switched in my pigtail... can someone verify that this is wrong or correct?
http://www.efisource.com/shop/gm-sty...sor-w-pigtail/
http://www.hondata.com/tech3barmap.html
Old Mar 15, 2015 | 10:15 AM
  #39
2JZFC's Avatar
Originally Posted by denmah
what size injectors?
sounds like VE table or injector size or something is off.
i use scaling 305 kpa
10.33 spacing
Will this MAP sensor be calibrated correctly if I just choose GM 3-Bar/MPHX6300 in the TS Common MAP Sensors list?
TIA,
Old Mar 15, 2015 | 09:13 PM
  #40
Fat Jesus 808's Avatar
Mine read 105kpa as well, but my car starts just fine with it
