Need help ASAP
Old Mar 6, 2014 | 10:11 PM
70c10's Avatar
Default Need help ASAP
Dropped off my manifolds and cross over today to get ceramic coated. The guy told me he will coat the inside/outside and flange faces on the manifolds. I told him to hold off and I would get some opinions first. I'm worried about coating the inside and having it flake off. And coating the flange faces I'm worried about the manifolds not sealing. Am I just paranoid or will it be ok?
Old Mar 6, 2014 | 11:10 PM
LT1PWRD's Avatar
Imho,I wouldn't coat any mating surfaces for reasons stated. I too would be worried about flaking hitting a turbine at speed. Just do outsides. Again, jmo.
Anyone else?
Old Mar 7, 2014 | 06:11 AM
Old Geezer's Avatar
Old Mar 7, 2014 | 10:01 AM
70c10's Avatar
Anyone else? Or should I just use some high temp vht and Dei wrap. Pipes are mild steel.
Old Mar 7, 2014 | 10:21 AM
Burken01's Avatar
I was under the impression not to wrap mild steel, it will warp with that much heat not being able to dissipate!
Old Mar 7, 2014 | 12:48 PM
70c10's Avatar
The owner of the shop said he does the inside and outside all the time.
Old Mar 7, 2014 | 12:50 PM
LS1NOVA's Avatar
Do the outsides and the flange sealing areas but not the insides.
If you want to save money VHT it. Ceramic only holds up a tad better anyway.
