5.3 blow through carb selection help
Old Mar 7, 2014 | 09:12 AM
boostedrides's Avatar
Default 5.3 blow through carb selection help
Ok guy's it's time to order a carb for my setup. I plan to start off at 12psi of boost and end up at 20+psi
I'm not really looking for a brand war, just cfm of the carb.
Combo will be.
Stock 5.3
Vic jr carbed intake
blow through carb 650 or 750?
DNA gt45 turbo
Cam isky triple 12
Feel free to help with ?s
Th400
Stall????
3"down pipe
2.25 hotside
Old Mar 7, 2014 | 10:12 AM
smokin03's Avatar
I have a new in the box blow thru carb PM me if interested
Old Mar 8, 2014 | 08:50 PM
LCW's Avatar
LCW
750CFM Quick Fuel with mechanical secondary for E85.
Old Mar 8, 2014 | 09:01 PM
I just came across a blow through quick fuel 750 on summit racing., you have any experience with these?
Old Mar 8, 2014 | 09:11 PM
LCW's Avatar
LCW
Not with the blow through carbs, but have a little with some N/A setups. They have great throttle response. What type of fuel do you plan on running?
Old Mar 8, 2014 | 09:17 PM
93 on 12psi and c16 on 20+psi. E85 is not that easy to find near me yet.
Old Mar 8, 2014 | 09:38 PM
LCW's Avatar
LCW
Give them a call, let them know your setup and they will hook you up.
Old Mar 8, 2014 | 10:42 PM
I will see what they have to say man. Thanks for the recommendation.
Old Mar 9, 2014 | 12:18 AM
vht's Avatar
vht
I've had QF carbs on NA set ups also. Great working carbs and the customer service is the best. I've emailed them before and they always get right back to me. Let us know the results, I may be in the market for blow thru.
Old Mar 9, 2014 | 01:33 AM
smokin91rs's Avatar
Default u
i did a holley 750 with the hanger 18 mods. my biggest problem was the power valves if your building a street car you will need them. i build boost fast and it was blowing the standard power valves shut and going lean after fighting it i bought a csu carb it seems to work but have yet to get it on the street because of winter. for some they work others not look in to the turbofourms. and the crutch setup if you like it. it works but i did like the idea.
Old Mar 9, 2014 | 06:15 AM
forcd ind's Avatar
a 750 will work for you, but do yourself a favor and buy one made for your blowthru combo, not one of the "shelf" carbs they sell as a blowthru
there are good builders out there, I only have experience with CSU, but have had several blowthru's, and the right carb makes all the diff,
more so as boost goes up
Old Mar 10, 2014 | 08:01 AM
[QUOTE=forcd ind;18072161]a 750 will work for you, but do yourself a favor and buy one made for your blowthru combo, not one of the "shelf" carbs they sell as a blowthru
I spoke with Kevin at csu, he will be building me a custom 750cfm carb for my combo. Thanks for the suggestions guys.
