t6 turbo?
Old Mar 11, 2014 | 04:35 PM
gallo-lo's Avatar
Default t6 turbo?
I'm starting a sloppy built for this summer, on a 65 malibu wagon and have built a lq9 spec O miles with tu2 cam and ss valves yell a terra rockers, comp spring 317 casting. .
Looking in using a 85mm turbocharger with 1.84 ar with 44mm wg. This is a blow thru build using msd 6010 , th400 9 inch tc 3600 stall and 3.42 gear. Maybe a taste of e85 fuel, open to opinions! ?
Old Mar 11, 2014 | 08:55 PM
HexenLord's Avatar
You sure about the specs on that turbo?
Old Mar 12, 2014 | 08:03 AM
gallo-lo's Avatar
Yes that's what is stamped.
