Turbo Cam
Old May 13, 2004 | 04:50 PM
slyws6's Avatar
Default Turbo Cam
https://ls1tech.com/forums/generation-iii-internal-engine/171312-turbo-cam.html
Old May 13, 2004 | 05:23 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Ls1's typically like a reverse split duration, with about a 114 LS. You don't want to much duration since you don't want to bleed down cylinder pressure. Around .560-.580 lift is about ideal. Their are tons of different options. Try contacting Seth and combination motorsports. He's VERY good with turbo cams on the LT1 and LS1's.
Jose
Old May 13, 2004 | 06:44 PM
F8L Z71's Avatar
12 Second Truck Club
I am gonna try out a 226/220 .591/.554 116 on my truck.
Should work well but who knows. Cam swaps are so easy in my truck that I dont care Hahaha
Old May 13, 2004 | 08:37 PM
slyws6's Avatar
lol lucky you it's a good couple of hours on my car. I'm thinking maybe something like a 230/225 .590/.570 on a 115lsa ???? How does this sound? Also how much advance should I have ground in for a turbo cam?
-Sly
Old May 13, 2004 | 08:39 PM
slyws6's Avatar
Hey FL8Pony, how do you have your Meth injection set up?
-Sly
Old May 13, 2004 | 08:54 PM
F8L Z71's Avatar
It's all being installed next week.
The Meth cell will be my stock coolant res. The nozzle will go into the intake tube right before the throttlebody. Other than that pretty simple. The dual stage boost controller will auto arm the system when flipped to Hi and there is a low fuel light for the Meth cell. It's a pretty slick kit. If interested check out this site.
Julio is the man!
AlkyControl
Old May 13, 2004 | 09:20 PM
slyws6's Avatar
Thanks, definately looks like a solution when I get around to pumping more boost into this thing. Put that on my favorites list for now
-Sly
