School me on Engine Delta Pressure
Old Mar 14, 2014 | 01:08 PM
Project GatTagO's Avatar
Default School me on Engine Delta Pressure
I've been having fun with the Airwerks turbo Match Bot putting together various combinations. I watched all of the BW tutorials and while they were very helpful, I am still a little confused about Engine Delta Pressure. Can someone please explain this to me?
Are positive values always desirable?
How much is too much?
What does it mean when the values go negative? Is that bad?
How negative can they go before it's really bad? Etc....
Thanks
Andrew
Old Mar 15, 2014 | 11:46 AM
Nobody knows? LOL
Andrew
Old Mar 15, 2014 | 03:45 PM
yenkomike's Avatar
here is some info I found. that might help.
DELTA PRESSURE (aka delta P): Describes the pressure drop through a component and is the difference in pressure between two points.
One other concept needs to be covered too, and that's the idea of air pressure vs. velocity. When a moving air column picks up speed, one of the weird things that happens is it’s pressure drops. So remember through all this that the higher the air velocity for a given volume of gas, the lower it's internal pressure becomes. And remember throughout all of this that I’m no mechanical engineer, simply an enthusiast who done all the reading he can. I don’t claim that this information is the absolute truth, just that it makes sense in my eyes.
Ok, so as you can see, backpressure is actually defined as the resistance to flow. So how can backpressure help power production at any RPM? IT CAN'T. I think the reason people began to think that pressure was in important thing to have at low RPM is because of the term delta pressure. Delta pressure is what you need to produce good power at any RPM, which means that you need to have a pressure DROP when measuring pressures from the cylinder to the exhaust tract (the term "pressure" is what I think continually confuses things). The larger the delta P measurement is, the higher this pressure drop becomes. And as earlier stated, you can understand that this pressure drop means the exhaust gas velocity is increasing as it travels from the cylinder to the exhaust system. Put simply, the higher the delta P value, the faster the exhaust gasses end up traveling. So what does all this mean? It means that it's important to have gas velocity reach a certain point in order to have good power production at any RPM (traditional engine techs sited 240 ft/sec as the magic number, but this is likely outdated by now).
The effect of having larger exhaust pipe diameters (in the primary, secondary, collector and cat-back exhaust tubes) has a direct effect on gas velocity and therefore delta P (as well as backpressure levels). The larger the exhaust diameter, the slower the exhaust gasses end up going for a given amount of airflow. Now the ***** of all this tech is that one exhaust size will not work over a large RPM range, so we are left with trying to find the best compromise in sizing for good low RPM velocity without hindering higher RPM flow ability. It doesn't take a rocket scientist to understand that an engine flows a whole lot more air at 6000 RPM than at 1000 RPM, and so it also makes sense that one single pipe diameter isn't going to acheive optiaml gas velocity and pressure at both these RPM points, given the need to flow such varying volumes.
These concepts are why larger exhaust piping works well for high RPM power but hurts low RPM power; becuase is hurts gas velocity and therefore delta P at low RPM. At higher RPM however, the larger piping lets the engine breath well without having the exhuast gasses get bundled up in the system, which would produce high levels of backpressure and therefore hurt flow. Remember, managing airflow in engines is mainly about three things; maintaining laminar flow and good charge velocity, and doing both of those with varying volumes of air. Ok, so now that all this has been explained, let's cover one last concept (sorry this is getting so long, but it takes time to explain things in straight text!).
This last concept is why low velocity gas flow and backpressure hurt power production. Understand that during the exhaust stroke of a 4 stroke engine, it's not only important to get as much of the spent air/fuel mixture out of the chamber (to make room for the unburnt mixture in the intake system), it's also important that these exhaust gasses never turn around and start flowing back into the cylinder. Why would this happen? Because of valve overlap, that's why. At the end of the exhaust stroke, not only does the piston start moving back down the bore to ingest the fresh mixture, but the intake valve also opens to expose the fresh air charge to this event. In modern automotive 4 stroke engines valve overlap occurs at all RPM, so for a short period of time the exhaust system is open to these low pressure influences which can suck things back towards the cylinder. if the exhaust gas velocity is low and pressure is high in the system, this will make everything turn around and go the opposite direction it's supposed to. If these gasses reach the cylinder they will dilute the incoming mixture with unburnable gasses and take up valuable space within the combustion chamber, thus lowering power output (and potentially pushing the intake charge temp beyond the fuel’s knock resistance). So having good velocity and therefore low pressure in the system is absolutely imperative to good power production at any RPM, you just have to remember that these concepts are also dependent on total flow volume. The overall volume of flow is important because it is entirely possible to have both high velocity and high pressure in the system, if there is simply not enough exhaust piping to handle the needed airflow.
It’s all about finding a compromise to work at both high and low RPM on most cars, but that’s a bit beyond the scope of this post. All I am trying to show here is how the term backpressure is in reference to a bad exhaust system, not one that creates good low RPM torque. You can just as easily have backpressure at low RPM too, which would also hurt low RPM cylinder scavenging and increase the potential for gas reversion. And understand that these tuning concepts will also affect cam timing, though that is again probably beyond the scope of this post. At any rate, hope this helps, peace. "
Old Mar 15, 2014 | 05:40 PM
That posting doesn't discuss anything related to turbo charging. The engine delta pressure that I am asking about is the difference in the pressure between the turbine side and the compressor side. I guess nobody knows...LOL
Andrew
Old Mar 15, 2014 | 08:21 PM
superhog88's Avatar
Old Mar 15, 2014 | 08:54 PM
qqwqeqwrqwqtq's Avatar
Andrew
Andrew, sorry I didn't realize that's what you were asking about before.
Generally, smaller turbos or combos that reach peak torque earlier will reach crossover point earlier (where turbine drive pressure exceeds boost pressure).
As for turbocharger selection itself, once you've decided on units that will be capable of your desired powerband, the only thing you can do is make sure it has a favorable compressor/turbine size ratio and keep the amount of inefficiencies in the turbo system to a minimum. (low pressure drop across cold side, minimize backpressure post turbo).
Many twin systems that reach peak boost/torque at say, 4k and below will have 2:1 or more backpressure ratio at higher rpm.
Systems that stay closer to 1-1 are going to be race oriented and making peak torque at a much higher rpm.
So really what it comes down to is choosing the turbo(s) that will give you the power curve you are after, maximize system/engine efficiency and drive pressure is what it is.
You can reduce drive pressure but it usually always comes at the cost of response, unless you are starting out with an inefficient turbo to start. (overtaxed turbine).
Old Mar 16, 2014 | 12:41 PM
Jim,
Thank you. I know that if anyone would know, it would be you...LOL
So, if the estimated turbine pressure is, for the sake of example, 30psi and the gauge boost pressure is 15 psi, then I have a 2:1 ratio of exhaust to intake pressure, right?
Andrew
