6.0 Heads?
Old May 13, 2004 | 07:39 PM
black_knight's Avatar
Default 6.0 Heads?
I hope this isn't a stupid question, but I have heard of both iron 6.0 heads and aluminum 6.0 heads...
What is the difference between the two? Obviously the iron is heavier, but are there any others? Is there a differant code for each? Which is more suitable for boost?
Old May 13, 2004 | 07:53 PM
F8L Z71's Avatar
12 Second Truck Club
Irons came on the 00' and below trucks and maybe 01'. I can't remember.
For forced induction you want the aluminum ones. The will help control heat and detonation better.
Old May 13, 2004 | 08:37 PM
Thanks, F8LPONY!
So, the aluminum ones come on the '02 and up trucks, then?
Which are the LQ9?
Old May 13, 2004 | 08:56 PM
F8L Z71's Avatar
02'+ for sure, maybe 01' also. I am not 100%.
LQ9 and LQ4 both have aluminum heads.
LQ9 is the Escalade 345HP motor and LQ4 is the standard truck motor.
Old May 13, 2004 | 09:00 PM
Okay. And the differance between the LQ9 and the LQ4?
Old May 13, 2004 | 09:08 PM
F8L Z71's Avatar
Heads are the same I believe. The LQ9 has more compression but I am pretty sure that is due to pistons and not head design.
I'm sure someone will be along soon to correct any mistakes I have made. If not ask this question in the Truck forum.
Old May 13, 2004 | 09:16 PM
Keith's Avatar
Rob Raymer tested both a while back on his turbo car. Should be in a search.
Old May 14, 2004 | 11:28 AM
Search is not forthcoming. And Rob is no longer here. Does anyone else know?
Thanks for everything so far...
 Michael S. Palmer
Old May 14, 2004 | 12:34 PM
Keith's Avatar
https://ls1tech.com/forums/showthrea...ighlight=heads
Old May 14, 2004 | 01:07 PM
Whistler's Avatar
Sawzall and Welder Mod
I've got an extra set of 6 litre aluminum heads if anyone needs a set.
Old May 14, 2004 | 02:52 PM
Well, now that I know his username is also Rob Raymer, searching should be no problem! Thanks!
Old May 14, 2004 | 02:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would not run iron heads, they are heavier and will retain heat more than aluminum heads. All 6.0 heads should be aluminum is they are 2001 and newer castings (off the top of my head).
Old May 17, 2004 | 01:43 AM
Mike 01WS6's Avatar
I believe the exhaust ports are different on the LQ9 vs. the LQ4. They have D shaped exhaust ports and are more like the LS6 heads.
So I believe it sorta goes like this: LQ4 is comparable to the LS1's (with less compression), LQ9 is comparable to the LS6's (with less compression). But don't take this as fact, this is just what I have gathered in reading and research over the years.
Old May 17, 2004 | 05:50 AM
smokinHawk's Avatar
no thats not it, lq4 and lq9's are identical, nobody has been able to tell a difference, the ports and volumes are the same. both ports are D similiar to the ls6 heads.
As y2khawk put it, the reason they have different casting numbers is because of were they are cast and made of different stock.
Old May 17, 2004 | 04:19 PM
Thanks for the info, all!
