P1SC questions
Old Mar 25, 2014 | 06:03 PM
Happy Jim's Avatar
Default P1SC questions
Hi all,
I have the possibility of buying a P1SC head unit, so as going FI is an itch that needs scratching I have some questions that I hope you can help me with.
This will be to go on my LS1 that sits in my AC Cobra Replica.
Engine is fairly stock LS1 from a 2000 Camero, Katech rod bolts, TR224/230 112 LSA Cam, block hugger headers, 2.5" dual exhausts, Zero emissions requirements. EFI Live in my possession.
Goals - north of 500 flywheel HP, south of detonated engine
I'll have to fab my own J bracket given my packaging limitations.
Questions:
What size bottom and top pulleys (6 rib) do I need? (Assuming Bob is still the man?) to hit my goals safely? (I would rather leave a few HP on the table than blow things up).
What size injectors (everything I've read says 60lb Siemans, if that is still the right move then where best to get them from please).
Is a BOV required? If so is there a "right" one to get.
I've got lots of space for an intercooler, is it just a case of "bigger = better" in which case I'll just over spec, or is there a magic formula to work out the size?
I'm in England so any links to places that ship would be appreciated.
Many thanks all
Jim
Old Mar 26, 2014 | 08:30 AM
Exidous's Avatar
60lb is just fine. Avoid ebay. There are a lot of china imposters on there for good prices. Any reputable shop in the states will sell genuine Siemans. I also know there are a number that are okay shipping internationally. Brutespeed comes to mind.
It's not technically a BOV. It's a bypass valve however you can use a BOV as long as it has a 1-2psi spring in it.
You can go too big in the intercooler. The bigger it is the more space that has to be filled. The most important thing is to get a vertical core. Like the one that treadstone sells. If your goal is 500bhp then Vertical core IC is a good choice. A little overhead but not too much.
I cannot speak to pulley size. (yet)
As far as a custom bracket goes you may want to look into a corvette style bracket. I have a forum buddy that custom made a corvette style bracket that sits lower then the A&A and procharger ones for my hood clearance. He runs an F1A and I'll be running a D1SC. I've seen in the engine bay of a couple cobra replicas personally and there really isn't much room to spare but up front isn't too bad. Good luck!
Old Mar 26, 2014 | 04:03 PM
Happy Jim's Avatar
Many thanks exidous, I'll go and have a look at the Brutespeed site and then do some more research on bypass valves & intercoolers.
I hadn't looked at Corvette or A&A brackets so I'll do those as well
Thanks
Jim
Old Mar 26, 2014 | 06:24 PM
ramairetransam's Avatar
you could run water meth and not use an intercooler ? You should see if you have room for an 8 rib setup .
Old Mar 27, 2014 | 02:55 AM
Exidous's Avatar
He noted that he had ample room for an intercooler. At 500bhp meth is not needed. The 8 rib is absolutely the way to go. You just have to have a little more room forward. The corvette stuff will require you to use the vette accessories and if you go 8 rib you'll need a pulley kit from ATI or Innovators west. It's about another $1000 but it's really worth it for the reliability and haggle free 8 rib. But if the budget it tight you can get away with 6 rib as long as it's the vette bracket. The Camaro 6 rib procharger bracket is total crap.
