EGT tuning with E85
Old Apr 1, 2014 | 05:56 AM
rkreigh's Avatar
Default EGT tuning with E85
not getting any feedback in the tuning section so I'll give it a go over here
https://ls1tech.com/forums/pcm-diagn...-wideband.html
thanks for any thoughts.
Old Apr 1, 2014 | 07:19 AM
hellbents10's Avatar
LS1Tech Sponsor
Depends on so many factors, comp, timing, boost, air temp, prob location......
I have seen them be happy from 1250-1600 depending on the setup.
Old Apr 1, 2014 | 08:30 AM
mike13's Avatar
would the egt be different than a comparable set up with gas?
Old Apr 1, 2014 | 09:59 AM
LS1Tech Sponsor
I have seen them be about 75-100*F lower then gas.
Old Apr 9, 2014 | 05:26 AM
rkreigh's Avatar
I'll give up a bit of power for a safe tune as I should have plenty
thinking right around 1300 is a good place to start
also interested in doing tune by cyl. some recent experiments on mr lee's car showed the EGTs were 300 deg apart when on the meth (I guess it's blowing back and making the rear cyl run rich
he went with a direct port meth and it really helped got it down to 100 deg apart without any tuning
Old Apr 10, 2014 | 10:50 PM
ls1CANTU's Avatar
Interesting thread. I want to run EGT setup on my car as well to fine tune. What EGT system are you running? I'm looking in to the altronics red alert system.
Old Apr 11, 2014 | 07:45 AM
LS1Tech Sponsor
Altronics system works nice.
