4.8 vs 6.0 hp difference
is the 4.8 your using a gen 3 or 4?
It will have a harder time spooling.
Most of the 4.8 turbo cams I do have 212-218 degrees intake duration.
Again this is what I already have, worse comes to worse i'll spray the damn thing!
278/286@.006"
226/231@.050"
147/149@.200"
113LSA 107ICL 119ECL
226/231 .605"/.598" 113+6
Compressor choke. It is determined by the isentropic efficiency of the compressor dropping low enough that it cannot flow any more air. Increased heat output lowers air density so power making capability reaches an asymptote, or choke point. A turbo will almost always make more power on a smaller displacement engine.
