what else is needed....
Old Apr 30, 2014 | 08:19 AM
munn79ta's Avatar
Default what else is needed....
i have a complete hot and cold side turbo kit with turbo/bov/wastegate. have 317 heads/hardened pushrods/headstuds and walbro pump. also have 2 bar map sensor for sd tune. motor is going to be 90k stock shortblock.
I plan on buying ls7 lifters, ls9 head gaskets, 60 lb injectors, fuel pump hot wire, pac springs, boost and a/f gauges and lastly a pusher fan setup... i thought about oil pump and timing chain but are they a must?
any recommendations on anything else im missing? not looking for specific hp goals just want to keep up or beat my buddies h/c/i car.
Old Apr 30, 2014 | 09:34 AM
SM105K's Avatar
What type of fuel are you going to run?
Old Apr 30, 2014 | 10:14 AM
munn79ta's Avatar
93 octane
Old Apr 30, 2014 | 10:28 AM
SM105K's Avatar
How big of a turbo do you have?
Old Apr 30, 2014 | 10:50 AM
munn79ta's Avatar
on3 76mm
Old Apr 30, 2014 | 10:55 AM
rotomoto712's Avatar
Intercooler and/or water/meth injection. That would ensure you can a good amount of boost on 93 octane, and it will help keep temps down.
Old Apr 30, 2014 | 11:01 AM
munn79ta's Avatar
i have a 4 inch intercooler already. i dont know too much about meth injection what size nozzels or exactly what mixtures or what to mix with water... noob here about that!!
Old Apr 30, 2014 | 11:10 AM
HolyShiznit's Avatar
Even with that small turbo you should crush a H/C set-up unless its on a stroker car with aggressive gearing.
Old Apr 30, 2014 | 11:32 AM
munn79ta's Avatar
well is a 02 shortblock with prc 227 heads and tsunami cam i built with him. goes to the dyno friday... so i will see then how it runs
