Twin BW s300's
I've heard about BW clones floating around ebay as well. I'd be nervous buying those. Still $1200 worth of turbo and additional plumbing/headache is overkill for 14lbs on a 5.7 IMO.
But I agree, a pair of 66's on a standard 5.7 is just silly. Not only oversize, but will probably spool crap too.
Unless the motor was forged, had a bit higher compression than stock and a well matched camshaft I feel that a stock headed/cammed 5.3 won't have enough VE to efficiently utilize those turbos.
They will spool slow(er) than a better matched turbo(s) and they will make less torque and under the curve than a better matched turbo.
Can you do it? Of course you can do it I have a customer right now running S366's on a 5.3 on 14psi with a custom grind that runs 9.20@142mph 3100-3200# RW.
It is an all out drag car though and under the curve and transient response mean nothing to him. On a street car though I think it's pretty important and not "BS" as one member mentioned.
Though I agree not all turds are created equal, and one turd may outshine another. It all Depends if 12 year old that assembled it knew his stuff, and if the recycled WOK melted down to create it was decent steel.
http://www.ebay.com.au/itm/Universal..._qi=RTM1714243
http://www.ebay.com.au/itm/Anti-Surg..._qi=RTM1714243
http://www.ebay.com.au/itm/T4-flange..._qi=RTM1714243
edit: should i change the thread title or make a new thread?
Ideally I wouldn’t pair a 70mm comp wheel with a 64mm exh wheel though either. I’d look for a pair of 60-63mm T4’s in the .68-.83 range.
Heres a couple...
http://www.ebay.com.au/itm/GT45R-2-G...14be5bf&_uhb=1
http://www.ebay.com.au/itm/T70-T04Z-...afb226f&_uhb=1
I cant seem to find anyone running these turbos to ask if theyre reliable at all, so im starting to regret my decision i bit lol, i guess time will tell.
I've read horror stories about others. I think you made a good choice based on the housing/wheel specs. When you get them I'd tear them down a bit look at the wheels, and make sure there isn't machining debris. Blow the oil ports out as good as you can and bolt those bad boys up!
How are these things size wise compared to some of the compact Turbonetics (Ashley or Lety) or Precision (6262 or 6265) units? I was considering something in the S300 series for my 408 that you did the cam for but since I want the turbos mounted similar to an APS setup space is at a premium.
I did have to re-work the oil fittings at the side of the block ( using Autokraft pan )and do away with the oil filter though, and switch to a remote filter, and oil return/scavenge was also tricky. With stock alloy pan you wouldnt have that same option I had to modify.
No idea what sort of space you have available on your car
AGP do some S200 based 61mm units that might be close to a lower 300, but in a smaller frame
Or the likes of the Precision 6266 can be had with the small 3"/2" inlet cover which is as small as you'll find.
