oil pan remove
Old May 6, 2014 | 06:53 PM
rorric's Avatar
Default oil pan remove
I got a oil pan that has been taped with return line I was wanting to know if I could remove it without dropping k member.. I have my trans pulled out and it looks like it can slide back if any one has onsite on this I would like to drop it out .
Old May 6, 2014 | 08:12 PM
crazyelf's Avatar
You won't be able to slide it back due to the pick up tube.
Old May 6, 2014 | 08:23 PM
stmz28's Avatar
Yes use can if you unbolt the motor mounts and jack the motor up. I just pulled mine yesterday with the trans in the car. That is with a bmr k member
Old May 6, 2014 | 08:50 PM
JAX04's Avatar
Dumb question, but why do you want to remove it? Is it an -AN fitting? you could always just put an -AN cap on it, or turbo it
Old May 6, 2014 | 09:19 PM
oscs's Avatar
I like option 2
Old May 7, 2014 | 05:54 AM
rorric's Avatar
Sorry I thought I put it on there but I had to get a new pan my has a small crack in the right front corner and couldn't get it to seal up so I figured I would just get another pan and in the process tap pan for future turbo. I have a bmr turbo k member to put in but maybe I swap it in onces the trans is in so the engine won't move .
Old May 7, 2014 | 06:06 AM
Troy5061's Avatar
I couldn't get mine out with the k member in but I also had my trans in too. I had to hold the motor up, take out the 4 rear k member bolts and take the front two out a few turns enough so it would pivot. Not much fun on the ground at 2 am lol, so glad I have a lift at home now.
Old May 7, 2014 | 10:08 AM
AutomagicLS1's Avatar
just go buy one of the engine bay hoists from harbor freight they are like 40 bucks. lower the k member right down
Old May 8, 2014 | 08:09 PM
rorric's Avatar
Sweet thanks just bought one ...
