intercooler piping sizes?
Old May 17, 2004 | 06:38 AM
69firebird's Avatar
Default intercooler piping sizes?
Hey got a question for you guys?
I got a new intercooler for my turbotech kit, and it has 3" inlet and outlets on it. I am going to redo all the piping and was wondering to me 3" seemed a little big, so here's the question
should I use 3" or 2.5"????
thanks for the help as always
ed
firebird455@onebox.com
Old May 17, 2004 | 08:12 AM
smokinHawk's Avatar
3" if it will fit.
when im getting my griffen installled 3" all the way.
the air will flow better which wont heat it up as much after the ic
Old May 17, 2004 | 11:08 AM
Tiago's Avatar
I have been wondering, if the turbo discharge is 3 inch and you are forced to reduce to 2.5 in. How much if any would you loose from the reduction?
Old May 17, 2004 | 11:16 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
No reduction in power per say, but you will be adding additional heat to the system. Typically you want to exit the same size as the discharge if possible, if not, larger.
Jose
Old May 17, 2004 | 06:55 PM
MYTURBOT/A's Avatar
In maximum boost it says that the inlet on the turbo compressor should be at least 1in bigger then the outlet on the compressor. So i'd recommend 3in IC piping with 4in inlet piping.
Old May 17, 2004 | 10:29 PM
69firebird's Avatar
well the outlet on my turbo is like 2" so i figured that 3" wouldnt be too big, but i didnt know if a t-70 would flow enough air to use the 3" i thought that maybe at that size pipe that it would loose some compression due to the space that it would have to fill up.
im not sure what I thought, but I asked, youall answered, and I ordered the 3" bends today to complete what I was going to do
again thanks alot
ed
