Incon TTi power steering lines
Old May 17, 2014 | 01:17 PM
silversweetZ's Avatar
Default Incon TTi power steering lines
Photo's courtesy of Modular Turbo.....I need help replacing my hard power steering lines. I've had several others chime in and give me part #'s but they have been for replacing the lines from the pump to the rack/pinion. I've circled the lines I need replaced in red. My turbo charge pipes go in between the motor and power steering lines under the alternator. Any assistance is appreciated!![IMG][/IMG]
[IMG][/IMG]
Old May 17, 2014 | 09:26 PM
Chris@CBR's Avatar
I looked into moving these lines at one time but I found nothing to work with that would screw into the rack.
It is GM "Bump Tube" on one end and standard looking flare on the other.
If I had to move these lines I would Silver Braze a -3 A/N fitting to the tubing as close as possible to the stock GM fitting and run -3 Teflon braided hose from point A to point B.
This is just and idea I had.
I found others ways to do what I needed to do.
Old May 18, 2014 | 11:16 AM
Sounds like it could work. Believe it or not this has been the most challenging part of my build. I only got 75% of the kit. It is brand new but because the fella moved 3 times he lost a lot of the little stuff including the relocated steering lines. I can't even find info on what size the ends are. I think the flared in is a 42* JIC fitting so i'll give what you suggested and that a shot.
Old May 18, 2014 | 06:40 PM
Marc 85Z28's Avatar
Do like everyone else did... heat them and bend out of the way.
