Fast dual wideband e85 conversions
Now in the tune of the motor in the GM ECU target stoich should be that of the fuel you are using. 14.7 or 9.76.
As an example: If you tune the motor using pure gas, no E10, and have the stoich set at 14.7, assuming tune is spot on, all you have to do to run E85 (fueling wise) is change that stoich number to 9.76. This does nothing for timing obviously unless it's a flex ECU.
