Install IAT in intake manifold
Old May 29, 2014 | 10:09 AM
stevieturbo's Avatar
Originally Posted by JAX04
Curious about something, you bring up the BOV placement in relationship to the Meth nozzle, what about people spraying pre-compressor?
It will have evaporated by then with pre-compressor.
Post compressor and near BOV is a little different. At WOT there is no problem, the engine consumes all.
However when you shut off the throttle, often water/meth will get expelled out the BOV. There isnt really any way to avoid that other than distance between nozzles and BOV to prevent it.
It may not be huge amounts, but it does happen...at least certainly with a supercharger that is continually pumping huge amounts of air
With a turbo..far less air would be moving once you lift off.
Old May 30, 2014 | 09:49 PM
locospl's Avatar
My IAT is the threaded type. Currently in the charge pipe via a weld in bung. I was going to move the IAT to the intake manifold and place the meth nozzle in the carge pipe where the IAT was moved from.
I am curious about any tuning problems this will cause.
Old May 30, 2014 | 10:31 PM
samdogmx's Avatar
i ran a water/meth nozzle in front of the bov last year, with no hood on the car it definitely got a little mist on the windshield after the finish line.
Old May 31, 2014 | 07:27 AM
locospl's Avatar
Going to start with one nozzle on pass side between BOV and IAT
