final questions on keeping a/c
Old Jun 24, 2014 | 02:39 PM
tallreyes's Avatar
Default final questions on keeping a/c
OK guys I'm ready to start my turbo build. But had a few questions before I do. OK I'm curious with the c6 manifold setup is there anyway I can squeeze this setup with a stock k member I plan on running the dp out the bumper.. I've searched but haven't found a for sure answer yet. The plan is a big single front mount setup. If it will not work I may just do my build the same as cam72aro did on his with fifth gen manifolds. Any help is greatly appreciated
Old Jun 24, 2014 | 07:34 PM
kylemm1002's Avatar
No. It won't fit. I installed my manifolds just to see before I dropped my k member. No way you are fitting a 2.25 pipe through there.
Old Jun 24, 2014 | 08:40 PM
tallreyes's Avatar
Kinda what I was thinking. But wanted a for sure answer just in case thanks for the info
