5.3 stock bore...best heads available?
Trick flow has GenX 205 heads designed to work specifically on that bore as well.
It sounds like your going all out with a turbo and methanol so you could probably step up to a larger head with larger valves. I don't think your going to be able to go past a 2.02 intake and a 1.600 exhaust valve with a 3.780 bore. Since your forced induction I don't think you will have to worry about valve shrouding and air stalling like an NA build would.
