Oil line length question
Old Jul 5, 2014 | 10:32 PM
kylemm1002's Avatar
Default Oil line length question
Sorry guys I tried searching but everything I found was for size of line not the over all length.
How important is the length of oil feed line to the turbo? I assumed shorter is better? But then I guess it's not "that" important because rear mounts use a really long feed line?
I can either use a 5' feed and run it around the engine bay and down to the oil filter housing?
Or
Use a 4' feed line and go under the intake, behind the power steering pump and straight shot to the filter housing?
Does it matter at all?
Might seem like a simple question but I would like input before buying the lines!
And on a drain over all legnth is 19" with say 8" of vertical drop then 4" of 45* drop then slops off pretty level (under the ac compressor) to the drain (pass. side of pan). It will have to enter the pan with a 90* fitting also.
Old Jul 6, 2014 | 02:39 AM
stevieturbo's Avatar
Both will be fine.
use -4 for the feed, and 5/8" for the return
