Help identify this turbo
Old Jul 10, 2014 | 09:47 PM
unnatrl's Avatar
Guys, I need help identifying this turbo or what it is similar to. It's a "custom" build, no markings. It was built by a shop in Phoenix Az. It's a T4 housing, 3" inlet to comp wheel and 4" v band for exhaust. The compressor wheel is 92.45 mm on the smaller diameter of the blades and 113.0 mm on the large side. The exhaust wheel is 76mm on the large side and 62 mm on the smaller side. I bought this a few years ago, the guy told me they put them on a lot of LS1's with great results. I don't think it will work well. I appreciate any info or suggestions.
Old Jul 11, 2014 | 04:18 PM
fire67bird's Avatar
Sounds like an ebay turbo and will probably work as long and it's not too small. I have a T3/T4 on my 4.3 V6 and it works fine. If it's a little bigger than mine it should be ok for a 4.8/5.3.
