pulley wobbles??? what do i do?
Old May 20, 2004 | 03:05 PM
vals1kid's Avatar
Default pulley wobbles??? what do i do?
my ATI crank pulley keeps wobbling and causin the belts to jump off. what do i do to stop this, or what could be casuin this? thanks.
Old May 20, 2004 | 04:02 PM
kp's Avatar
kp
It probably loosened up if its moving around that bad. I would check it before you drive it anymore..
Old May 20, 2004 | 05:47 PM
NA$TY-TA's Avatar
Or worst case... like me a long time ago... you worped the seat wear the crank pulley is sapposed to sit and now you have to buy a new balencer. I bought mine for $95 from the dealer....... or like KP said..... the bolt came lose. TQ it down to 250FTLB's and use some red loctite.
Kyle
Old May 20, 2004 | 06:41 PM
lcvette's Avatar
How did you install it? if you used the toold, it whould have gone on straight.. if you used something to beat it on you may have scarred the crank or the hub.. I have seen both done before on some backwoods cam swaps.. never fun telling a customer he needs a new crankshaft..
Chris
Old May 20, 2004 | 06:44 PM
kp's Avatar
kp
You dont have to pull the balancer to put the ATI crank pulley on, it sits on top of the stock damper. But they have and do loosen up since ATI doesnt give the crank pin kit with the F-body kits for some odd reason..
Old May 20, 2004 | 07:59 PM
vals1kid's Avatar
thanks guys. well its probably not tight enough (i hope). the balencer doesn't wobble just the pulley, and would the pin kit help it out alot?
Old May 20, 2004 | 08:44 PM
Black LS1 T/A's Avatar
Moderator
Your crank bolt may be bottomed out and not holding the pulley on tight.
Old May 20, 2004 | 08:53 PM
Got Me SOM's Avatar
sell that kit and buy a vortech.
Old May 20, 2004 | 10:14 PM
vals1kid's Avatar
no thanks ill stick to the ATI. i used 3 washers, but my guess is i jsut didn't tighten it down enough. oh well in the morning ill check.
Old May 20, 2004 | 11:07 PM
Packy's Avatar
No way!!!
Old May 21, 2004 | 12:50 AM
BIGBOS's Avatar
3 washers seems like a lot
Old May 21, 2004 | 12:08 PM
Moderator
I had to use 4... before I cut the bolt to use only one. Results vary.
