How Much Power???
Old Jul 29, 2014 | 05:01 PM
dodgesruck's Avatar
Default How Much Power???
Like all first time turbo ls builders I'm curious what the masses think of my combination (power wise). What better place to find out than ls1tech. I'm still a few months away from completion (lets see a few is 3) scratch that some months away but here goes with what I'm building.
Vehicle: '85 c10 swb - pump gas
Engine: '06 5.3l truck engine
Modifications to engine: Rings gapped to .26 & .28, ls6 valve springs, new oil
pump other than that stock ??? miles.
Ignition: MSD control box with factory coils
Fuel delivery: Fuel cell, Bosch 044 pump, -8 lines, Aeromotive regulator,
Victor Jr. intake, CSU 750 blow thru carb.
Induction: Twin CXRacing T4 GT35 turbos, Godspeed twin intercooler,
twin 44 gates, flipped manifolds, spectre carb hat.
Drivetrain: Ptc spec converter, TH400 trans, 3.42 gears with a spool, 28 or
29" tires.
Boost & Timing: Looking for 12-14lbs at 13 to 14 on timing.
I know stock builds have been done before and I may have not have done the best job of searching but this is what I have. I can't take many recommendations as most of this has been bought but please feel free to give your opinions. Thanks.
Old Jul 30, 2014 | 09:52 AM
dodgesruck's Avatar
Wow 130 views and no guesses or opinions yet. I thought this would be a no brainer for the folks on this site. Someone has to have an opinion good bad or ugly.
Old Jul 30, 2014 | 10:23 AM
TINKRD's Avatar
a very general rule of thumb for turbo setups is it takes around 14.5lbs to double N/A HP. (14.5lbs is doubling atmospheric pressure).
Old Jul 30, 2014 | 04:22 PM
dodgesruck's Avatar
Thanks for the reply, I just figured there would be some real world examples or even some thoughts on my combo. I would post this in a truck forum but nobody has built more ls turbo engines than the people on this sight.
Old Jul 30, 2014 | 04:58 PM
mrstepheneades's Avatar
Stock cam? I'd say 600ish being it's twins. Just a guess. Like stated above it usually takes close to 15 psi to double your na power which would probably be low 300 range thru auto on yours. 15 psi being in low to mid 600s. Maybe. Had a ta long time ago with basically same cam spec I used in my boost ta I got now. Na is about 400 rwhp thru t56. 16psi made 775 rwhp with single s475 on a otherwise stock ls1. So that saying is true or close for most setups.
Old Jul 30, 2014 | 05:03 PM
dodgesruck's Avatar
Yes stock cam. I'm saving the good parts for the other 5.3l I have sitting in the corner. Just throwing this combo together to learn what I did right, what I did wrong. What works and what doesn't. Thanks for the reply.
Old Jul 30, 2014 | 05:06 PM
I also have twins going on a 5.3 block. But gonna be more like 30psi lol.
Old Jul 31, 2014 | 05:49 PM
denmah's Avatar
Moderator
probably 550whp and some serious tq i believe those are on the smaller end of turbos should spool fast and make tons of tq
try to keep the tuneup mild down low if you can with timing might bend some rods, i made 800+ftlbs at like 3000rpm with a twin gt35 kit (60mm turbos i believe mine were)
 Michael S. Palmer
Old Jul 31, 2014 | 07:02 PM
fire67bird's Avatar
A friend of my wife's cousin told me about a guy he went to school with who's dads coworker ran a similar setup. You should be bringing in about 900hp at 25 psi boost.
Old Jul 31, 2014 | 08:51 PM
dodgesruck's Avatar
I like those numbers Denmah. I guess I should have included some turbo specs.
Brand : CXRacing GT35 T4
Air Inlet : 4"
Compressed air outlet : 2.5"
Exhaust outlet : 3"
Compressor : .70 A/R
Turbine : .68 A/R
Compressor Wheel : 61.3/82mm
Turbine Wheel : 62/67.8mm
Old Jul 31, 2014 | 10:59 PM
denmah's Avatar
Moderator
stock cam just upgraded springs?
Old Aug 1, 2014 | 06:56 AM
dodgesruck's Avatar
Yes the stock cam. Buddy of mine had the springs just sitting so I figured I'm throw them on.
Old Aug 1, 2014 | 08:46 AM
dodgesruck's Avatar
Since we're somewhat on that topic what is the stock cam good for as far as rpm wise. Just curious how high people have turning these. Thanks.
Old Aug 1, 2014 | 12:16 PM
denmah's Avatar
Moderator
well if its stock cam and springs it will quit pretty early like high 3s
stock cam doesnt make power over 4800 usually its definately falling fast by 5500 by hundreds of hp usually
Old Aug 1, 2014 | 12:17 PM
denmah's Avatar
Moderator
stock springs in my experience cant hold much more than 10lbs also
so more boost will = less power
Old Aug 1, 2014 | 02:37 PM
dodgesruck's Avatar
So about 5500 rpm max and hope that the ls6 springs can hold a little more than 10lbs. This helps alot when I get ready for my converter.
Old Dec 5, 2014 | 10:41 AM
65chev's Avatar
Did you ever get this setup going? I was looking into those same turbos for a 5.3, wanted to know how they panned out.
