6l80e reliablility boosted application Im in the process of upgrading my 5.7 lt to a L77, i have acces to a cheap 6l80e, been toying with the idea of using this instead of my r151 manual, 4wd application) build threadhttps://ls1tech.com/forums/forced-in...onversion.html who has a stock 6l80e behind boosted motor, pros and cons, any info appreciated. Gus |
I have the stock 6L80E in my GrandSport with an ECS kit, Long Tubes, Alky Control Meth injection. Made 612 in the heat - this past 4th of July https://lh5.googleusercontent.com/-a...0/IMG_1016.jpg 2 things that have been done to my transmission are a GOOD TUNE and an external Transmission cooler with a fan. The tune is said to be the most vital part of the equation with 6L80E units - I offer that a good cooler is a close second! No matter though, I wouldn't advise looking for reliability past the 625 rear wheel power point without a performance build - and there aren't many places building them. Whats the chance of a 6L90E fitting your build? Said to be a lot stronger than the 80e, if you must have a 6 speed auto. Good Luck. |
Originally Posted by Alex in Houston
(Post 18352017)
I have the stock 6L80E in my GrandSport with an ECS kit, Long Tubes, Alky Control Meth injection. Made 612 in the heat - this past 4th of July 2 things that have been done to my transmission are a GOOD TUNE and an external Transmission cooler with a fan. The tune is said to be the most vital part of the equation with 6L80E units - I offer that a good cooler is a close second! No matter though, I wouldn't advise looking for reliability past the 625 rear wheel power point without a performance build - and there aren't many places building them. Whats the chance of a 6L90E fitting your build? Said to be a lot stronger than the 80e, if you must have a 6 speed auto. Good Luck. |
The 90e is about 3/4" longer on the front side of the tranny - hard to tell just by looking at the pan like you could between a 4L80 - 4L65. Truth be told, I hardly ever tap the paddles - like almost never. I mostly shift to S and depress the loud pedal to get forward thrust. I could not care any less about "rowing gears" in a damn car ever again this life time. If you've got the 4L80 - and the only reason you want the 6L80 is for paddle shifting - run the 4L80. If you just must row gears throw the manual in there My $.02 |
62naldie was pushing over 700rwhp on his boosted crew cab denali through a 6L80e. |
© 2024 MH Sub I, LLC dba Internet Brands
