Spark Plugs for FI 2014 Silvy
Old Aug 11, 2014 | 04:55 PM
SRTKLLR's Avatar
Default Spark Plugs for FI 2014 Silvy
We installed a Maggie kit on a 2014 Silverado and need some colder than stock plugs. The truck is making 10psi at the moment with a smaller pulley but the stock plugs don't last lomg cause they are too hot for a supercharged application.
Need recomendations on plugs and part numbers.
Thanks
Old Aug 11, 2014 | 06:51 PM
Iam Broke's Avatar
If stock HR is a 5 like I suspect, go to a non extended tip NGK BR7EF. You don't need a glowing flamethrower sticking out into the combustion chamber at 10 psi on pumpgas.
I run 6's but I'm on E85 at 10 psi and the 7's carbon tracked from being too cold.
Old Aug 13, 2014 | 10:17 AM
turboventura's Avatar
7's on e85 19lbs, 8's were fine under boost but got nasty with just a few street miles.
Old Aug 14, 2014 | 05:48 PM
SRTKLLR's Avatar
Those plugs won´t work on the new 2014 trucks because they come with the DI engine. The plugs are longer with more thread.
That is what I need a part numberr for a 7 or at the very least a 6 in cold range.
