SQ g trim failures?
Old May 21, 2004 | 11:41 PM
blown98z28!!'s Avatar
Default SQ g trim failures?
How many people have had their SQ gtrim fail on them and what were the circustances? Also how many people have the SQ gtrim on the car and it has not failed and how long have you been running it? Thanks
Old May 22, 2004 | 06:44 AM
somebody has to have a story
Old May 22, 2004 | 07:30 AM
Inspector12's Avatar
TT-TECH Veteran
Look at my post about mine Locking up!
Old May 22, 2004 | 07:40 AM
did yours lock up because of a bearing failure or because of a gear failure?
Old May 22, 2004 | 11:14 AM
Got Me SOM's Avatar
believe its a design flaw with the bearing, btw its only on the sq trim not anything else.
Old May 22, 2004 | 11:55 AM
TT-TECH Veteran
If you read the post SJH has the problem figured out pretty much the gears that are cut to keep it quiet produce side load on the bearing under fast reving the load increases more than the bearing is designed for and I can tell you my motor revs very fast and yes the bearing is what went. If you are using it in its stock form on a stock motor I think you will be fine but if you are going to mod it I would get one that makes noise (Strait cut gears).
