turbo 5.3 build problems finishing. HELP!!!!!
only time i had an issue is on those 90 degree nights at the circle track i had it go above 210 while i was sitting in the pits with the AC on after a lap or so, turned ac off no issues after it had time to catch up
with that being said just make sure everything matches up with what ur setup is running and u shouldn't have an issues, make sure fans are both wired correctly (not sayin u did but sometimes u can miss the simplest things).
id also check what ur fan turn on temp is, think mines like 210 low speed 215 high, so u might ether need to turn down the temp they kick on at or let it go to 215 at idle and just keep a sharp eye on it, letting it get to 215-220 at idle and watching it closely wont be a huge issue but i wouldnt make it a habit about doing it a lot ether.
