Upgrading top end on turbo build.
Old Aug 23, 2014 | 07:08 AM
MonmouthCtyLS7's Avatar
Default Upgrading top end on turbo build.
Currently running hand ported 04 Z06 heads and a Typhoon 85/85 setup...Im wondering if upgrading to a bigger Holley single plane intake, bigger TB, and some cnc'd heads would see any gains.
Old Aug 23, 2014 | 07:59 AM
Blackpanther99's Avatar
Sure would.
Old Aug 23, 2014 | 08:09 AM
Next question is can I fit a single plane under a SS hood?
Old Aug 23, 2014 | 10:37 PM
coolmanvette75's Avatar
You will make the same amount of power on less boost with a better flowing setup, which is easier on parts. Lol. This is one of the reasons I have a lot of money in my top end...
Old Aug 24, 2014 | 09:20 AM
2000RATA's Avatar
If those heads are ported right you won't pick up a whole lot from those heads. Having a cam custom ground to your setup would likely yeild larger gains than from the heads. But no doubt a set of AFR heads or the like will flow better.
