stock bottom end f1A
Old Aug 29, 2014 | 02:06 PM
NitrOmm's Avatar
Originally Posted by The Alchemist
I love seeing direct comparisons like this to get an idea of the direct differences between the two. I'm at the limit of my D1SC and am considering an F1-? on my setup, which is a forged 347, so seeing the comparison is very relevant to me. Any other changes made Evan like intercooler size or inlet or cam or was it a direct swap between D1SC to the F1-A?
Id be interested in seeing the low end comparison re: TQ. I would assume that 1.5# less boost would account for 27# less in peak TQ. How will it look at 3K - 4K RPM ?
I still have trouble wrapping my head around bigger vs smaller blower: obviously a bonehead like me can understand that a bigger blower is capable of pushing more air volume and pushing it with more efficiency
(less cannibalizing of power, better/ lower IATs etc,,,) for peak numbers. I also know that boost is never a measure of power. What I cant understand is how a certain level of boost (a measurement of resistance) can produce more power than the same level of boost (same level of resistance) in one blower to another. In this case its even more of a divergence as the boost is lower at 9.5# to the smaller blower @ 11#.
Did I just answer my own question ( is it all in the efficiency ) ?
Old Aug 29, 2014 | 06:08 PM
Mike 02T/A's Avatar
Do you happen to know your IDC % on the new dyno #'s? I'm running 60# injectors and I def need something bigger. Thinking about buying SD 80s or maybe the next step up.
Old Sep 2, 2014 | 12:46 PM
01boydws6's Avatar
Mike I do not, but Fran may be able to answer that when he post's the graphs.
Old Sep 2, 2014 | 05:11 PM
Firehawk441's Avatar
(less cannibalizing of power, better/ LOWER IATs etc,,,)
The F1A is creating less heat at lower RPM's then the D1SC spinning at a higher RPM.
I've seen F1D's outperform a D1SC the very same way.(Same boost. Different performance.)
So yes....You answered your own question.
Old Sep 3, 2014 | 09:09 AM
NitrOmm's Avatar
Thanks for clearing that up for me. Sometimes the obvious answer is the right answer.
Old Sep 5, 2014 | 11:08 AM
01boydws6's Avatar
here is the graph.
It would have been a better comparison if I was at the same psi of boost on both set ups
Old Sep 5, 2014 | 04:41 PM
The current impeller speed you have right now puts the F1A at a disadvantage.
It takes more engine speed to peak higher at a loss across the board.
From the looks of that graph, the D1SC would've kept climbing had you run further out in RPM's like the F1A.
Having both peak boost/peak RPM's equally would be a perfect comparison.
Thanks for sharing.
Old Sep 11, 2014 | 11:40 AM
01boydws6's Avatar
next year I will be pullying it for 12#s and adding some meth so we will see what happens then, right now its fun just having the car back together after being apart for 9 months.
Old Sep 11, 2014 | 02:04 PM
Mike 02T/A's Avatar
Throw a decent set of heads on it and you'll be happy. I'm running the same pulley and blower, different cam.
Old Oct 27, 2014 | 12:01 PM
BradSV8's Avatar
what size was the crank pulley?
Old Oct 27, 2014 | 01:48 PM
Mike 02T/A's Avatar
7.65, should be anyway.
