dynoed sts kit today
all have a little more time now that we don't have to post on this board.
if the IDEA, STORY, and WHAT WORKS FOR THEM is 10psi with thumper from hell then the only bullcrap is YOU criticizing that.
How old are you two? Grow up and agree to disagree. A few of you are so cutting edge with performance, can you tell me how to get my car to slow down to get back to only running 12's?
and im 20 so i dont have the big bucks to drop a whole paycheck on gasoline for my car.
You cannot, motor for motor, if using some type of forced induction, make the same power with pump gas versus race gas. You cannot attain the same boost levels using pump gas versus race gas. Does this mean I go out and fill up? No, but when I want more power, compared to just running pump gas, I either put in a few gallons of race gas or turn on my alcohol injection.
On the other hand, if I want to blow up my motor and build a new one, I'll just run the pump gas and watch my boost gauge hit 17psi while the piston comes out the side of the block.
BTW, I see you do not have a turbo or blower on your car, so why are you arguing with me about running race gas? I was only saying this pertaining to forced induction cars. You have a N/A car with fairly moderate compression so you can run pump gas all you want, YOU will gain nothing running race gas. Thanks for understanding...
having 5.7l worth of spooling muscle and not using it to spool something big is like having blank and a girlfriend and not blanking her. get it?
1) you make no sense
2) you don't own a turbo car
3) you have no clue what your talking about, and finally...
4) pose your theory, whatever it is, to Rob Raymer or Kenny Duttweiler and see what they say...
I'm done with your idiotic nonsense. I will help the people that need help, obviously you don't need help due to being so smart and knowing it all about turbos...good day.
-Geoff
https://ls1tech.com/forums/forced-induction/186377-amacgt-s-10psi-sts-dynograph-w.html
I took the graph off my server because only a handful of people showed interest in it and I need the space back to host some other things. But trust me it put down what he said it put down.
J
amc can you repost your setup info, what turbo, what psi , what impeller and what engine and fuel system mods
ta12sec, it is a 347 with diamond pistons 9.2:1, crower rods, ls6 intake, z06 cam, pace longtube headers, sts turbo kit with gt-67 with .86 exhaust housing, 36lb. inj. walbro fuel pump, methanol inj. i run half 103 unleaded and half 91 octane. 15psi, nx kit, 3.42 gears
WHERE IN THE HELL IS THE 10 PSI GRAPH????!!!!!!!!!!!
