GM cam
Old Aug 27, 2014 | 09:01 PM
vht's Avatar
vht
Default GM cam
What GM cam will work good in a boosted 6.0? Would like a 3 bolt and just need something right now for a street rod project.
Old Aug 27, 2014 | 09:03 PM
oscs's Avatar
LS6 seems to be a popular choice
Old Aug 28, 2014 | 05:16 PM
93camaro_zzz's Avatar
LilJohn says to run LS6 cam. They are the best. lol
Old Aug 28, 2014 | 06:47 PM
Mongoose350's Avatar
I've herd the LS9 cam is pretty good too.
Old Aug 28, 2014 | 09:46 PM
Jose93z28's Avatar
Ls6 here with good success on my 5.3, also I got a friend running one on a 6.0 lq4 with a rear mounted turbo on an fbody as well around 12 psi, the ls9 will work as well but if your cam sensor is on the back of the engine you will need 05 ls2 front cover, 05 cam sprocket, camshaft extension harness, 05 ls2 chain dampner.
