ISKY Triple 12 and S475
Old Aug 28, 2014 | 01:58 PM
viper6549's Avatar
Default ISKY Triple 12 and S475
I already have the cam from previous project. So do I have a custom cam spec'ed out or just role with the 3x12
3500 Fbody
TH400
5.3 Truck intake lightly ported 862
3:50 Gear 28" tire
S400SX4-75mm with Standard Cover. 96x87mm Turbine with 1.32 T6 Exhaust
Pretty much a track car
Old Aug 28, 2014 | 02:09 PM
denmah's Avatar
Moderator
my 5.3 / isky / 76etrho worked great together
Old Aug 28, 2014 | 05:32 PM
viper6549's Avatar
I will run the 3x12 thanks....
Old Aug 28, 2014 | 07:09 PM
stock48's Avatar
9 Second Truck Club
It should work well long as you are not turning crazy RPM. Should be able to run mid 150's mph with that combo. Need to check advance on cam I grind them per application so advance can vary. Id run it in on 110 intake centerline for that application.
Old Aug 28, 2014 | 09:41 PM
dmaxvaz's Avatar
What's crazy rpm's?
Old Aug 29, 2014 | 07:52 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by dmaxvaz
What's crazy rpm's?
Over 7k. After 6500 rpm it's going to start losing steam.
Old Aug 29, 2014 | 09:33 AM
viper6549's Avatar
Thanks for the reply's. The cam's grind is two degrees advanced.
