Turbo guru help needed - leaking coolant!
Old May 22, 2004 | 06:52 PM
White_Hawk's Avatar
Default Turbo guru help needed - leaking coolant!
I am still (after two months) in the process of installing a stage one incon kit. I filled up the coolant last week and yesterday noticed it was dripping out of the driver's side turbo. I pulled the manifold. and found the coolant hose fitting to turbo joint leaking at the copper washer. Of coure it was at the one that I couldn't access as usual...
How do you torque this thing properly? I tighten it to the spec but when I put the hose on it it comes loose. Is there some kind of trick?
Thanks for the info.
-Geoff
Old May 22, 2004 | 10:52 PM
red ws6 99's Avatar
-Geoff
I have no issue getting to any of those connections as far as I can remember but this is with a PA k-member. Of course I have a full set of wrenches and sockets that I had to modify to get into the tight places on Incon kit. I may of modified one but don't remember modifing one of the 17 or 18 mm wrenches for the water lines. I did modify a 12 mm, spark plug socket, 15mm and a few others for clearance.
Gary
