Please Help! Maggie 112 questions
I am in need of some help, I have searched the entire internet twice and all that has done is just confuse me more! I wand to build a FI LS on a budget (just like everyone else in the world!) around a magna charger 112. My goal is to achieve 500 to 600 hp at the crank. The 112 came off a truck and now I am looking for the appropriate long block combination to deal wit the Maggie limitations. I know that I will be limited to 10# of boost max before the blower just becomes too inefficient due to heat soak. So I am leaning towards a 10.5 CR. I am hoping that I can get to 550 ish with 10# and 10.5 CR then add meth to get to 600. I have resigned myself to the fact that I wont be able to find a LQ9 so my choices are the LQ4 or the 5.3. If I start with a LQ4 - what heads are the best budget heads to use? Do I mill a set of 243's or go with the 317's. On each of them how much should I mill them? I am planning a LS9 or LS7 cam. Additionally if I go with a 5.3 and the same cam how much should I mill the 317's on the 5.3?
Thanks!
If you run a 5.3l do not put 317s heads on as you will loose too much compression for the 112.
They can make 550 hp at the flywheel with a very simple setup.
PS: I have an ECS HD tensioner & multiple 8 rib pulleys that I am selling. PM me if your interested.
