Turbo smoking
Old Sep 10, 2014 | 05:50 PM
F110Mech's Avatar
Originally Posted by V-seriesTech
I get a lot of people in the shop asking about similar issues.
Before you restrict any turbo...ensure that the oil drain is correct sizing(T4 turbos-10 at least- T6 turbos -12 at least). Once your sizing is good...then you need to look at the drain line itself. It needs to flow like how a water slide would.... no high spots...all smooth shot from turbo into pan or return area. If all of those stars align,...and you have a smoking turbo...then I would look POSSIBLY into a restrictor.
a -4 feed line on a T4 should flow the same as a -4 feed line on a T6 so a -10 drain should be adequate for either, no?
Old Sep 11, 2014 | 05:21 AM
stevieturbo's Avatar
Depends on the sizes of the galleries inside the turbo.
Whilst you're providing it with -4, that doesnt mean the internal oilways are exactly that.
Old Sep 11, 2014 | 01:13 PM
V-seriesTech's Avatar
Largest possible drain is wanted...in my experience anyways. General rule...for what I would recommend anyways which, is just an opinion. T3/T4 I would use -3 feed/-10drain and T6 -4 feed/-12 drain.
Old Sep 11, 2014 | 03:33 PM
F110Mech's Avatar
Does RPS sell a -12 drain kit? If I'm gonna do it it's going to be before the motor goes in.
Old Sep 11, 2014 | 03:34 PM
oscs's Avatar
Just buy the fittings and measure for the hose.. You'll save yourself some money. There is no "cookie cutter" awnser to this problem. The only constant in a gravity drain journal bearing turbo application is to minimize all restriction if possible. The bigger the better.
Old Sep 11, 2014 | 03:56 PM
We do sir.
Old Sep 11, 2014 | 04:20 PM
F110Mech's Avatar
Pre packaged from RPS is actually cheaper
Old Sep 11, 2014 | 05:14 PM
oscs's Avatar
Depends where you buy your AN stuff I suppose. My supplier is hard to beat.
Old Sep 12, 2014 | 01:44 PM
Old Sep 12, 2014 | 01:57 PM
oscs's Avatar
Lmfao rick flair? That was pretty good.
Old Sep 12, 2014 | 02:35 PM
LOL
WOO!
Ever since Eastbound and down came out.....we've been "WOOing" every day lol.
Example? (not work safe) lol
Old Sep 12, 2014 | 05:18 PM
  #32
oscs's Avatar
LOL WOO! Ever since Eastbound and down came out.....we've been "WOOing" every day lol. Example? (not work safe) lol Video Link: http://youtu.be/GoWblwKdeHg
Kenny powers is my hero
Old Sep 13, 2014 | 12:57 PM
  #33
93camaro_zzz's Avatar
How can you come to that conclusion not knowing what turbo he has? If it's a standard journal bearing turbo than there should be no issue running a 4an and no restrictor.
He said what turbo he had in his OP. And I came to my conclusion because a buddy of mine has that EXACT same turbo, and when he ran unrestricted line, it would blow past the seals and smoke. Put on a 0.060 restrictor and all is well. My turbo was the exact same situation, but mine is a Garrett T6 turbo. 4AN smoked, 0.060 did not.
When it comes down to it though, the "right" way to do it, is to find out what the manufacturer of the turbo wants for oil pressure in the cartridge. And you would restrict down to that pressure for when your setup is at high rpms.
Old Sep 13, 2014 | 01:49 PM
  #34
oscs's Avatar
Originally Posted by 93camaro_zzz
He said what turbo he had in his OP. And I came to my conclusion because a buddy of mine has that EXACT same turbo, and when he ran unrestricted line, it would blow past the seals and smoke. Put on a 0.060 restrictor and all is well. My turbo was the exact same situation, but mine is a Garrett T6 turbo. 4AN smoked, 0.060 did not. When it comes down to it though, the "right" way to do it, is to find out what the manufacturer of the turbo wants for oil pressure in the cartridge. And you would restrict down to that pressure for when your setup is at high rpms.
Right Since all the journal bearing turbo companies I've spoken with clearly state that a restriction voids warranty. Whatever works for you though I guess..
Old Sep 13, 2014 | 04:45 PM
  #35
Thanks! Non-smoking turbos work for me!
Old Sep 13, 2014 | 04:51 PM
  #36
Also, for your reference, here is the link to Garrett's website. Which nowhere it states about voiding a warranty.
http://www.turbobygarrett.com/turbobygarrett/faq
Originally Posted by Garrett's website
Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo. The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
Old Sep 13, 2014 | 06:54 PM
  #37
oscs's Avatar
Also, for your reference, here is the link to Garrett's website. Which nowhere it states about voiding a warranty. http://www.turbobygarrett.com/turbobygarrett/faq
Lol @ the first question in the FAQ it's referring to a BALL BEARING turbo. So I wonder what the second question is directed towards?
Old Sep 13, 2014 | 07:07 PM
  #38
Chevy_King1500's Avatar
put a .065 restrictor on my magnum 72mm. stopped the smoke
Old Sep 13, 2014 | 07:27 PM
  #39
You're right. Good job on not even reading the second part.
Old Sep 14, 2014 | 12:21 AM
  #40
oscs's Avatar
"last ditch effort" is all I needed to see
