403 with twins cam change
Old Sep 5, 2014 | 06:07 PM
1fastxz's Avatar
Default 403 with twins cam change
Thinking about changing the cam in the car to see of i can get a little more power out the set up.
Iron block
403 cu block
APR main stud kit
APR head stud kit
Brian Tooley Lifters
ls2 lifter trays
C5R timing chain
Trick performance cam retainer plate for using LS2 timing chain tensioner
LS9 head gaskets
4.005 bore Wiseco -20 pistons
4.00 stroke Eagle crank and rods, with armor coating.
LS3 heads with hollow stainless intake valves, Inconel exhaust valves
heads were decked for flatness
Stock Ls3 intake
92LB injectors at 3 bar.
Lonnies double intake fuel system with billet fuel rails
APS with LGmotorsports turbos
LG motor sports upgraded turbos
New CHRA (Center Housing Rotating Assembly)
New Inconel 71x Turbine Wheel with new 2009 technology
Billet Compressor Wheel ( ~ 60mm inducer) that flows ~ 70lb/min
New Compressor Cover machined for new Compressor Wheel
70mm Inlet
Cam in the car was spec for a 4.8 motor.
Cam spects are
226/237 115.5+6 605/610
Thinking about switching it out to a speed inc TU1.0 or TU1.5
its a street car 2005 GTO full car. 4000lbs
car is making good power now. Just looking to turn the boost up and find a cam that will work better.
When I got this set up tuned power didn't pick up pass 14lbs.
Tthanks
Old Sep 5, 2014 | 07:37 PM
toytech93's Avatar
Most shelf cams are designed for single turbo combos. Call around to shops and find something you think fits your needs. I would recommend LJMS, lil john Motorsport solutions
Old Sep 6, 2014 | 09:03 AM
ScreamingL's Avatar
Changing Names
have a 402 going together with twin 7668s
using a JFR 224/224 112
Old Sep 6, 2014 | 03:42 PM
1fastxz's Avatar
Think it's going to be the TU1 225/225
From what I've been finding twin turbo's seem to like the straight up duration cams
Old Sep 6, 2014 | 10:13 PM
ta02zx10r's Avatar
Give Martin a call at tick. He does a lot of turbo cams and has a lot of knowledge about the whole cam situation.
Old Sep 8, 2014 | 08:52 AM
LilJohn's Avatar
Twin turbo motors usually like camshafts that look alot like a blower cam.. Normally they can handle a bigger split and more overlap due to the additional turbine... but in this case with those APS units... the turbines are a little undersized for the size of the motor. That being said I think I would be 230/239 117+4 on something like this. This spec put 900 to the ground with an APS kit on a Corvette a couple years back.
Was the car tuned on a chassis dyno??
Old Sep 8, 2014 | 10:49 AM
1fastxz's Avatar
Right now the cam in the car has a large split in it. I think I'm getting to much pressure coming out the exhaust.
The car has duel 3in exhaust and straight threw mufflers.
Old Sep 8, 2014 | 02:20 PM
LilJohn's Avatar
Your current cam has .5 degrees of overlap at .050
a TU1.5 has 4.....
If you have a backpressure issue now... changing over to a camshaft with MORE overlap... is only going to make the problem worse.
 Michael S. Palmer
Old Sep 8, 2014 | 06:07 PM
1fastxz's Avatar
a TU1.5 has 4.....
Good to know.
Going to give you a call tomorrow.
Old Sep 10, 2014 | 11:43 AM
qqwqeqwrqwqtq's Avatar
a TU1.5 has 4.....
So you think that combo should be running negative overlap?
While I wouldn't say there are huge gains in store with a cam swap, reducing overlap at this point will reduce power.
Old Sep 10, 2014 | 03:19 PM
1fastxz's Avatar
How do you think the TU1.0 would work in this set up?
Old Sep 10, 2014 | 06:28 PM
LilJohn's Avatar
Maybe it would Maybe it wouldnt.... With turbines that small and THAT many cubic inches its hard to not be in an excessive backpressure situtation.
But I can tell you this.... 231/239 118+2 made 940+ to the tires in basically the same combination and was still picking up power above 14 psi where his is not and it had -1 degree of overlap.
Old Sep 11, 2014 | 12:27 PM
1fastxz's Avatar
So my question still is
Who has a cam that would work good in this set up?
Old Sep 11, 2014 | 01:01 PM
I'm sure it would. His lack of power gain after 14psi is likely not due to the cam.
Old Sep 11, 2014 | 01:02 PM
It would work good but so should your current cam.
If it's not picking anything up after 14psi I would look at valvesprings or see if the induction leading to the turbo inlets is collapsing.
