need help with boost builder holley efi
Old Sep 18, 2014 | 10:11 PM
tempoffroad's Avatar
Default need help with boost builder holley efi
I have the dominator and have the two step wired to a ground and set for 2600 in the ignition parameters on the rev limiter number 1 with hard limint with timing set. I don't have a transbrake yet. I want to enable the boost builder by checking manual boost builder enable and use the same ground from the two step to a pin map for boost enable. Then I will just check fixed timing and go from there. Is that all that I need to do. Thanks
Old Sep 19, 2014 | 05:42 AM
LS1NOVA's Avatar
Thats how mine is setup.
I have both on the same ground with boost builder being activated at 4psi. Works great on the footbrake. Spools up nice and quick and once it hits 4lbs, boost builder retards timing. I can make 12 on the footbrake in two seconds.
Old Sep 19, 2014 | 08:55 AM
great thanks!
