Keep nipping the #7 plug.....
We currently have a car we built and tune that is running in the 5.20's on C16 that has 250+ IAT's with 28psi of boost and it has more timing in the tune than yours. Albeit the AFR on my car and that car is richer than yours. We run -10 heat range non projected tip NGK plugs in both cars.
I would ditch the methanol injection if you're running C16. No need for it now.
What heat range plug?
I am still running Br7EF plugs because micro does not like non-resistor plugs.
Mike
I think that plug is too hot as well, but some run them with success.
