5.3 with ls7 heads and 70mm turbo work?
Current build idea
Iron 5.3 wouldnt that be stronger?
ls7 heads
z06 cam
ls6 intake magnifold
60 pound injectors
tial bov and wastegate
70mm turbo .96ar 6ish psi
through a b&m built for 700hp 4l80e
3000 stall
to a 12 bolt with 3.73 gears
profit at:
low to mid 4xx at the wheels
How much slower would a
76mm .82 A/R spool to like a MP 70mm .96ar
Either way, for $450 your best bet is a set of 317s/243s. Those will easily outflow any LS1 or 5.3 head and fall within your budget. The others will work also for your goals, but why not get the best head possible for your budget?
Use stock heads with a decent valve job. More than enough to get you to 500+ hp.
what is your hp goal
76mm means nearly nothing its only one of at least 4 important numbers on a turbo when you are sizing up what kind of power you want to make.
gt45 68mm if you can fit it
on3 76/65 very fast spool
on3 7875 little slower spool but capable of more power
all are under 450 dollars
use the stock heads, a mild turbo cam, pac1218 springs and youll be nailing it down without issue, without blowing tons of money on ls7 hardware
Thinking maybe either
S400SX-62 ETR-HO 71mm .90ar
or
PRECISION TURBO 7075H (T4 .96 A/R)
with the current idea
Iron block 5.3 take out
317 cast heads
ls6 intake
and i have no clue what would be a mild turbo cam I'm guessing something like a
comp cam XR265HR
what are the thoughts on rebuilding say a $700 4l80e with the 4L80E SS MEGA MONSTER TRANSMISSION COMPLETE REBUILD KIT and a shift kit
or
buy the b&m built 4l80e
As far as the cam....ideally a custom cam is killer but even some of the other OEM cams like the LS6 or even LS9...there are others.
