Turbo gears can it work ????
Old Oct 16, 2014 | 07:53 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by yenkomike
15 years ago I ran a buick gn with a 100 octaine tune it ran 11.40s with the 3.42 gears for 2 years. I picked up a 9" axle for it and it had a 4.00 gear I thought it whould fly . it ran 11.80s . I tried to make it work but it just didn't like it . I had a stock 3.00 gear laying around and just for the street I decided to swap it in and I could not believe how good it felt so I took it to the track . ran a best of 11.08 whould run 11.20 every pass .
as a side note the best 60' it ever ran was with the 3.00 gear. 1.48 @3700#
Im going to test your theory shortly. Switching from a 8.5" 10 bolt to a 3.08 12 bolt. No 3.23's a available for 12 bolt. Adding about 50 lbs too. We'll see what happens.
Old Oct 16, 2014 | 09:52 AM
Forcefed86's Avatar
FWIW I think a lot depends on the gearing in the trans you use.
With my old turbo 3.8 rx-7 I went from a 3.27 to a 3.08 to a 2.73. I picked up Et and MPH with every change. 28” tire 200-R4 trans. Had an excessive slip in the converter though (16% or so). Also only weighed 3000ish lbs. Swapped in a powerglide and I couldn’t pull the 2.73 on the launch. Had to put the 3.27 back in.
Old Oct 16, 2014 | 11:02 AM
yenkomike's Avatar
i was convinced that if i could hold the rpm at peak torque the full pass the car whould be fastest.
Old Oct 16, 2014 | 12:51 PM
Jamescassy's Avatar
Default :)
Originally Posted by STEVE PWC
Im running a 275 pro and a 296/55/15 drag radial on my S-10. Rolled Quarter lip 5 inch back spacing. 373 gears spool
Thanks
Jamescassy's Avatar
Default :)
thanks
Old Oct 16, 2014 | 12:52 PM
Jamescassy's Avatar
Default :)
Thanks
Old Oct 16, 2014 | 09:11 PM
Jamescassy's Avatar
Default Nitrous
Would nitrous help get on boost and stay there ?
Old Oct 18, 2014 | 07:23 PM
Jamescassy's Avatar
Default 100 shot ?
Would that help ?
Old Oct 19, 2014 | 11:09 PM
Jamescassy's Avatar
Default :(
Can I hit it off the line with nitrous , then once it gets full boost let off the nitrous and get there with a tall enough tire ?
