to big of turbo?
That's a bit small then for 850. A BMW476 would do the job, or a cast S480. An 83mm TW with a 1.10 housing would be ideal, and would spool dramatically better than a 96mm TW in a 1.39.
Honestly though, you wont need 850whp to go 9s unless the car itself is set up VERY poorly.
Jack
I’d guess your 5.3 isn’t making much more than 290 or so at the wheels. So that’s 580ish at 15bs 870ish at 30lbs. That also assumes the turbo was efficient at those levels. A S471 wouldn’t be. And S475 with the small wheel wouldn’t be. Either way you need more than 11lbs to reach your goal.
I think the Apex S475 turbo is a great turbo for a 5.3. It’s a 1.10 T4 with a 77.5mm/87mm wheel. One of the best deals out there right now. It has the ability to run high 9’s pretty easily IMO. They also have optional 1.25 T4 housings and a billet 11 blade 75mm compressor.
http://www.ebay.com/itm/Borg-Warner-S474-90-1-00-1-10-A-R-Twin-Scroll-T4-Turbo-S400-/221572610895?pt=Motors_Car_Truck_Parts_Accessories&hash=item3396c1bb4f&vxp=mtr
Or spray what you have on the line and be done with it.
I think the Apex S475 blade turbo is a great turbo for a 5.3. It’s a 1.10 T4 with a 77.5mm/87mm wheel. One of the best deals out there right now. It has the ability to run high 9’s pretty easily IMO. They also have optional 1.25 T4 housings and a billet 11 blade 75mm compressor.
Borg Warner S474 90 1 00 1 10 A R Twin Scroll T4 Turbo S400 | eBay
Jack
With my 5.3 and small cast s475, I stopped making big gains after 23psi or so. Also I saw 2.8:1 back pressure ratios at 25lbs. Picked up 4mph at the same boost going to the apex S476 with the larger 77.5mm wheel and the 1.25 T4 housing. Back pressure dropped to 2.15 ish. This was also with the small 2.5" outlet compressor cover.
I switched over to a super tight converter meant for a 6.0 making big power. Ended up running a spare 4.8 for the rest of the year. The 4.8 wouldn’t come up on boost at all with this converter. Hit it with a 60 shot for 1200rpm or so on the brake and boost was instant. Honestly I think a setup like yours would be ideal for a record breaking SBE single setup.
Put a Cast 80mm S400 on it with a 96mm turbine and a 1.10 A.R housing and Be done with it... it will run its *** off I promise you that... Call me or Jose at FI and we can get you setup. that turbos 999.... and I will give you free shipping as a perk.
