370/ new f1A-94
Old setup:
Stock Ls1 with custom blower cam
Normal boltons
D1 procharger 8 rib 4.25" pulley
Aster bracket
Alkycontrol single nozzle meth/pump gas 93
M6 and 9"
Made 671/565 on roughly 12ish pounds
New setup - motor just dropped off at the machine shop and blower parts being ordered any day now:
6.0 iron block .030 over
Wiesco -3.2cc pistons 10.3:1 compression
ls9 headgaskets
ARP head studs and main studs
Callies compstar rods
Stock Ls3 heads
Stock Ls3 intake
90mm TB
Custom grind blower cam
ls7 lifters
Procharger Intercooler kit
New F1A-94
3.70" pulley
8 rib and Aster setup
Probably just a screen on the blower
ATI Dampner
1 7/8" longtubes into true duals
ditching the meth and going E85
still a 6 speed but upgrading the clutch to a Mcloud RXT twin
Same 9"
This is all I can think of for now. I'm hoping for 900+ pretty easy but we will see!
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
F-1A-94 = New F-1A w/ 3.70 new design impeller, new 9” volute.
Compared to an F-1A, The F-1A-94 has a more aggressive backsweep on the exducer of the impeller. Generally speaking, anytime you add more angle to the backsweep you are decreasing the amount of pressure to build at low RPM, and it will be probably feel noticeably softer down low. Up top the F-1A-94 is good for around 150-200 more rwhp over a standard F-1A. Bob
