pushrods I was wondering what pushrods I should go with... 5.3 I got a tick performance turbo cam they recommend hardened push rods how do I find out what pushrods I need way too many choices to guess Lol thanks |
Our house brand push rods are made by Trend and are an excellent choice. I personally like to use a .105" wall 5/16" diameter in this type of application if the customer's budget allows. The .105" wall push rods are more expensive, but stronger. |
Originally Posted by Martin@Tick
(Post 18500896)
Our house brand push rods are made by Trend and are an excellent choice. I personally like to use a .105" wall 5/16" diameter in this type of application if the customer's budget allows. The .105" wall push rods are more expensive, but stronger. Jack |
Originally Posted by cptinjak
(Post 18500971)
What is the weight difference between those and standard 5/16? What's the benefit vs runnning an 11/32 pushrod? Jack Thicker pushrods are just stronger.. Don't bend as easy. Just a theory though.. :bomb: |
Originally Posted by JustAFooL
(Post 18501182)
Thicker pushrods are just stronger.. Don't bend as easy. Just a theory though.. :bomb: Jack |
Check the..
(Post 18501958)
I'm aware. I'm asking why someone would do a thick wall 5/16 instead of the 11/32 PR. Jack |
Originally Posted by Old Geezer
(Post 18502057)
rod clearance going thru the head..... Jack |
(Post 18500971)
What is the weight difference between those and standard 5/16? What's the benefit vs runnning an 11/32 pushrod? Jack Push rod weight is something that has never concerned me and if you ask any of the top engine builders that I'm certain Bullseye associates with, they'd tell you the same thing. Most customers at this level do not wish to spend the added cost on larger diameter push rods so I offer the thicker wall 5/16" at a slightly higher cost and as a better alternative to .080" wall 5/16" push rods.
(Post 18501958)
(Post 18502065)
That's an easy fix. I've seen people run 3/8" before. Jack Again, cost is a factor and a straight tube 3/8" will not clear in most factory casting or even aftermarket casting LS cylinder heads. I've even had some customers have issues with dual tapered 5/16-3/8 diameter push rods. |
(Post 18502193)
Jack, Push rod weight is something that has never concerned me and if you ask any of the top engine builders that I'm certain Bullseye associates with, they'd tell you the same thing.
(Post 18502193)
Most customers at this level do not wish to spend the added cost on larger diameter push rods so I offer the thicker wall 5/16" at a slightly higher cost and as a better alternative to .080" wall 5/16" push rods. Again, cost. If the customer is willing to spend the added money for the 11/32" or larger it is always a plus. Jack, Again, cost is a factor and a straight tube 3/8" will not clear in most factory casting or even aftermarket casting LS cylinder heads. I've even had some customers have issues with dual tapered 5/16-3/8 diameter push rods. Thanks for the info Martin Jack |
(Post 18502210)
I agree. I was just curious. Weight is always second to stiffness, but it's not totally unimportant. I worked for Visner Engine Development for years (that's how I met Bill and started at Bullseye) so I'm rather familiar with valvetrain theory. Perhaps my time at VED makes the thought of epoxying PR tubes into the intake ports a lot less scary to me than to others because I'm so used to pushing the limits of cast heads. I'm the kind of idiot who just spent a few months hacking up a pos pro comp and building my own short runner large plenum intake manifold out of the base of it (just used the flanges and TB snout basically) because I didn't want to buy a FAST (I recommend just buying a FAST). Thanks for the info Martin Jack I agree that weight is second to stiffness especially on the lifter side of the valve train. I'd add weight on that side of the valve train any day of the week to gain stiffness. Journal diameter, lifter diameter, push rod diameter(which I always would rather have a larger diameter push rod than a thicker wall) and push rod stiffness are critical to keeping things from flexing in the valve train. The more power the engine makes, the more this becomes a concern. As you most certainly know from working at Visner! I agree about push rod tubes! There is an Edelbrock casting that a cylinder head shop we use offers. He will add bronze push rod tubes so that up to a 3/4" diameter push rod can be used. I always use the biggest diameter push rod the head can fit and a customer is willing to purchase cost wise. I would LOVE to see some pictures of that intake manifold you fabricated as it sounds like something right up my alley! LOL |
(Post 18502306)
Jack, I agree that weight is second to stiffness especially on the lifter side of the valve train. I'd add weight on that side of the valve train any day of the week to gain stiffness. Journal diameter, lifter diameter, push rod diameter(which I always would rather have a larger diameter push rod than a thicker wall) and push rod stiffness are critical to keeping things from flexing in the valve train. The more power the engine makes, the more this becomes a concern. As you most certainly know from working at Visner! I agree about push rod tubes! There is an Edelbrock casting that a cylinder head shop we use offers. He will add bronze push rod tubes so that up to a 3/4" diameter push rod can be used. I always use the biggest diameter push rod the head can fit and a customer is willing to purchase cost wise. I would LOVE to see some pictures of that intake manifold you fabricated as it sounds like something right up my alley! LOL I'm a bad welder. Don't judge me. There are some in-process pics here: https://www.facebook.com/media/set/?...6255259&type=3 https://scontent-b-ord.xx.fbcdn.net/...fd&oe=54AA5573 Jack |
That manifold is pretty slick. I agree that running the biggest diameter pushrod is always a good idea. I know my PI heads have the ability to run some pretty thick ones. I may re-evaluate what I'm running soon. |
Missed the pictures of the manifold, WOW! |
(Post 18507970)
Missed the pictures of the manifold, WOW! Jack |
If that's what you call a hack...... LOL |
(Post 18508478)
If that's what you call a hack...... LOL Jack |
Jeez, that manifold looks awesome! Do you have any pictures during the process? |
Originally Posted by dangkhoavu
(Post 18509892)
Jeez, that manifold looks awesome! Do you have any pictures during the process? Jack |
a bigger diameter pushrod is better than thicker wall from what I hear. |
© 2024 MH Sub I, LLC dba Internet Brands
